TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Compression Test Consistent but interesting....
WolfmanZ
on August 26, 2014 at 10:32 PM
posted by BLACKTT3Z
on August 26, 2014 at 10:23 PM
Are those numbers lower than where a healthy TT engine should be or fine because they are within range?
WolfmanZ
21:56:33 08/26/14
Put a small amount of oil into a cylinder or two and see if
jzack
22:05:28 08/26/14
Re: Put a small amount of oil into a cylinder or two and see if
WolfmanZ
22:28:08 08/26/14
BLACKTT3Z
22:23:46 08/26/14
WolfmanZ
22:30:51 08/26/14
Re: Re: Compression Test Consistent but interesting.... -
WolfmanZ
22:32:44 08/26/14
Re: Re: Re: Compression Test Consistent but interesting....
BLACKTT3Z
23:21:49 08/26/14
if he knocks the price down...
wickdGSXR
11:33:59 08/27/14
FSM says 171 standard, 128 min for TT (n/m)
BlackholeZ
20:30:16 08/27/14
if the balance tube was removed it doesn't matter if the
aliaZ
12:50:08 08/27/14
Was the engine warm?
-Grimm-
09:34:56 08/27/14
Re: Was the engine warm?
WolfmanZ
13:40:05 08/27/14
Those are good numbers considering the test conditions
-Grimm-
16:26:23 08/27/14
engine temp doesn't have that much effect (n/m)
aliaZ
12:50:02 08/28/14
I beg to differ
-Grimm-
12:35:10 08/30/14
I believe your observation was an outlier (n/m)
aliaZ
16:34:56 09/03/14
Re: Retest tonight with throttle open showed the following..
WolfmanZ
20:11:04 08/27/14
It's fine.
BlackholeZ
20:40:09 08/27/14
A test often not done is a vacuum test with engine >>
ZUL8TR
05:54:49 08/30/14
